cruising speeds with 351 and pumper carb, speedometer off, and gas mileage?
Old 08-24-2009 | 01:20 AM
slippery750's Avatar
Originally Posted by LearjetMinako
Just re-pluck the needle a little bit to correct the error. Its not perfect, but it works good enough.
Huh?
Old 08-24-2009 | 03:03 AM
MaverickAus's Avatar
Originally Posted by kpwestmo
so maverickaus, basically what im hearing is once i get the pumper carb and 351 kit, I will have ALL the power I need and then some? Im only interested in being able to cruise comfortably at 65 REAL SPEED... and mainly focused on "trail riding" power.. and I just want to have that snappy, poppy throttle response where the front wheel can be stood straight the **** up with a simple snap of the throttle and a slight pullage on the handle bars... but it's not like real jolty, or dangerously annoying with the pumper carb, right? ANd should I get the 33? 35, or 36? what would u recommend? and what are, if any, the key differences between the aforementioned pumper carb sizes?
No it's not real jolty and most probably not even notice it. I have no experience with the other carbs only the Bill Blue modified Mikuni TM33. IMO if you do the 351 and carb, have it tuned right and raise the gearing, you will have no trouble getting the front wheel up and cruise all day at 65
CC_Rider
09-04-2014 08:33 PM
2007 Green Machine
07-10-2011 02:37 PM
kpwestmo
04-27-2010 09:29 AM
SlapDrum
02-19-2010 05:28 AM
SlapDrum
01-03-2010 06:19 PM
Quick Reply: cruising speeds with 351 and pumper carb, speedometer off, and gas mileage?
