Cruising speed with BB 351
Hmmmm.....then why are you wanting to go to a big bore? Have you considered doing at least the front suspension first?
Exactly. My stock-geared 2009 turns 6000 rpm at 60 mph indicated. It's actually how I know I'm in 6th gear...the rpms are 100 times greater than my speed. 4500 = 45 mph, etc. My bike will run 70 mph indicated up the steepest of hills around here.
...at any given rpm, the speed will be exactly the same no matter the displacement.
Well, I guess I should have stated my reason for the 351. It is very hard to maintain speed in 6th gear at 60-65 with just a small amount of wind. I thought by going to the 351 that this would help me maintain speed without having to constantly down shift to 5th gear. I have no interest in going any faster than 65-70 indicated, that's why I said I'm not looking to go fast. Am I looking in the wrong direction in order to maintain speed, or am I on track here.
Yes you are on the right track.. I was having a hard time maintaining 70 indicated unless I crouched down and was completely on a flat surface.. with a 351 you can sit up and go 87 indicated. I put a speedodrd (speedhealer) so my speedo is exactly same as GPS, and last night I passed a car going up hill at 84 MPH (GPS) going slightly up hill (okay I crouched down slightly) Its an incredible upgrade.
I'm not up to speed on what a speedhealer is. Can you tell me a little about it please.
AH, yes. In that case, the 331 does the trick, so, I'm positive the 351 should be able to do it even better. I simply didn't want to get into wet sleeves, seeing as how the low temp tomorrow is 91 here, with a high temp of 112 expected. I thought it prudent to go with the largest dry sleeve, which was the 331. You are on the right track!
12oClockLabs speedo-drd its a small chip that you plug in near your instrument cluster.. then you program it to compensate for the 8.6% that the stock speedometer reads.. My speedometer was reading 8.6% faster than GPS speed.. now, the speedometer is dead on accurate.
Thanks!
