Crankcase breather hole size?
Old 11-13-2009, 12:16 AM
Some engineer on the klx300 design team calculated the blow by on the rings and calculated an opening diameter that would prevent the build up of pressure wot with crappy rings.....a guesstimate.
There diameter picked....it is not performance based decision, its maint based...preventing buildup of pressure reduces likely hood of oil leaks.
Perhaps later someone looked at the diameter guesstimate and said wtf was he smoking it does not need to be that big and then it was smaller.
I'm an engineer...we do that sheet all the time.
Old 11-13-2009, 12:33 AM
I kind of like the idea of the one-way pcv valve which actually maintains a slight vacuum inside the crankcase on the upstroke instead of a bi-directional vent to atmosphere. I put one of those on my current bike. I sure can't tell any performance difference, but knowing it's there makes me feel better.
Old 11-13-2009, 01:31 AM
Smile
I don't know NoBrakes, I would think a slight positive pressure would be better than a vacuum..... only because if my bike had a slight oil leak and I was doing a water crossing that vacuum could help migrate water and other contaminates into the case.
Small positive pressurization amounts do have their merits...like keeping the outside stuff outside.
Old 11-13-2009, 01:47 AM
Pros and cons either way. Six in one, half dozen in the other. Maybe its best just to leave the dang thing alone and go ride instead.
Old 11-13-2009, 01:58 AM
lol....I miss Iowa, he lived for this carp.
Just got our first cold front...woooo hooo it may get below 70
Taking tomorrow off work, hitting the scrub wot on the adv in her stripped down lc4 enduro version....going solo so I got an EPIRB in the backpack in case a tree does not move.
Old 11-13-2009, 01:59 AM
RimBender's Avatar
The ball in a pvc valve can't react quick enough to the changes in pressures, it'll be open when it needs to be closed etc. Bike motors that utilize this kind of vent control use reed valves (ducati) or some kind of timed mechanical driven device (H-D).
Old 11-13-2009, 03:02 AM
dmar's Avatar
I remember hearing that enlarging the hole would give better throttle response.
  #28
Old 11-13-2009, 03:31 AM
neilaction's Avatar
Yep, so we all blindly enlarged it.
cliffsta
06-06-2009 07:43 PM
sinkoman
01-25-2009 01:05 AM
Savagekilla
08-18-2008 05:10 PM
chris72a
12-23-2007 10:11 AM
Quick Reply: Crankcase breather hole size?
