Crankase klx250-cilinder 300cc
Greetings to all klx!
Could anyone tell me if the crankcase of the klx250-2009-cylinder 300cc (292cc) tolerate without being cut off?
Is that in this description says: Crankcase machining is required.
http://japan.webike.net/products/2111236.html
That fact has left me pensive and confused ... ..
Hard to believe a sleeved cylinder like that would need the crankcase opening enlarged to accept it. The Bill Blue 351 is a sleeved cylinder, and it drops in directly into all later model...at least '06 and later...KLX250's. I don't know what year model was the last 250 that required the crankcase to be trimmed to accept the KLX300 cylinder, but it was quite awhile back. Your '09 should be fine.
That would make more sense.
Be careful with the web bike English site, it isn't translated very well. Japanese site is here XRfS ONLY ƒGƒbƒNƒXƒA[ƒ‹ƒYƒIƒ“ƒŠ[ PERFORMANCE FORGED PISTONSi’b‘¢ƒsƒXƒgƒ“ƒLƒbƒgj KAWASAKI KLX250R—p | ƒoƒCƒN—p•i’ʔ̂ȂçWebikeyƒEƒFƒrƒbƒNz‚Ö
Japanese site says crankcase machining is NOT necessary.
※スリーブの交換が必要です。クランクケースの加工は不要です。
Run that through a translator
I also thought it would be a mistake in print.
Thank you all, you are about craks!
From the vendors website parts are:
Weiseco piston WE03-0250
Bore 78mm
Displacement 292cc
Compression 11:1
Uses OEM head gasket (probably KLX300)
Vendor is Marukawa racing MARUKAWA RACING
Difficult to navigate but from that link, on the top left click on "Net Catalog" (not my spelling), then click "Enzine". You should be able to see many engine parts.
Nobrakes
02-08-2008 02:05 AM
