Could a KLX survive an EMP or Solar Flare
Old 12-19-2013 | 08:22 PM
ol'klx-er's Avatar
The CDI is a little computer that provides the spark, it would be toast. Therefore no go for bump starting the KLX.
Old 12-19-2013 | 08:35 PM
durielk's Avatar
I dont' quite know how the spark system works on the KLX, it has no points, the major components should be ok. But the suspect parts would be a computer board or chip that would be the first to fry.
Better to go with the first blast of the elec pulse, what is left is a slow passing & a lot of pain.
Old 12-19-2013 | 10:23 PM
wildcard's Avatar
you might want to do some reading on the effects of emp on non-grid connected items (ie cars, bikes, etc).
they are not nearly as sensitive as most people and the alarmists think.
emp can travel over transmission lines very easily and knock out computers, lights, etc. also the grid itself acts like a giant antenna capturing electromagnetic waves and makes the problem worse.
that kind of power transmitting through the air to build up in the frame (antenna) of your klx and fry the cdi ? the fillings in your teeth would probably be melted before you realized you bike wouldnt start. and im not talking about a nuke blast per se. that kind of energy production to emit a pulse that powerful would be quite a show i would think.
Old 12-19-2013 | 10:32 PM
RayCour's Avatar
A solar flare induces disturbances on the power grid because it encompasses large distances. The disturbed power grid in turn may cause harm to electronic and electric equipments connected to it.
The KLX is not grid connected, thus it will survive solar flares without problem. An EMP event, however, be it from a nuclear blast or an EMP bomb, is a different beast. If you are close enough to it that the KLX electronics (CDI, instrument panel) are affected, I don't think there is any practical means to be immune to this. Anyway, you will have bigger problems if such a thing occurs...
Old 12-20-2013 | 04:32 AM
SageGrouse8139's Avatar
I don't understand this discussion at all but I covered my helmet with aluminum foil just in case.
Old 12-20-2013 | 05:13 AM
RockabillSlapMatt's Avatar
better be safe than sorry
Old 12-20-2013 | 04:30 PM
I've had the Arai version of the helmet you speak of for some time.
Attached Thumbnails Could a KLX survive an EMP or Solar Flare-tin-foil-helmet.jpg
Old 12-20-2013 | 04:43 PM
On a more serious note, the more I've read about EMPs, the more I understand them not to be damaging to humans. There are tons of good and bad studies and commentaries on EMPs. The best testing has probably been done by governments (military etc.), and they usually don't release all they know as fact about the results or methods of protection.
The one part about why EMPs are not damaging to most living creatures is that fact that the nervous system, while a kind of electronic circuit, is not continuously "joined", "cabled", or wired like most electronics. Our nervous system has synapses that don't appear to support the channeling of the EMP's damaging elements.
In reality, however, I think most of us know that unless you're heavily immerssed in the actual science and study of an EMP event, the question about how our KLX might respond to an EMP probably involves a lot of fun but useless conjecture.
I found this article to be fairly interesting.
Electromagnetic Pulse - EMP Myths - futurescience.com
Old 12-20-2013 | 05:15 PM
I think if your bike is OFF when the emp hits, better yet the battery disconnected, there will be a less likely chance of a fry. On the other hand EMPs are their own power source so it could power up and fry your electrical system still...but not as a high of a chance when its on and running.
Old 12-20-2013 | 05:34 PM
Brieninsac's Avatar
The question wasn't meant to be a discussion of EMP theory, but to identify the bike components that could fail and subsequently prevent the bike from running. The problem is the last major EMP occurred in 1859, well before cars were invented. So we really don't have any reference on how vehicles and motorcycles could be effected.
Quick Reply: Could a KLX survive an EMP or Solar Flare
