Coolant Leak from Weep Hole below Thermostat Housing
Old 10-27-2011 | 09:12 PM
When removing the thermostat and cover to install the ThermoBob, it was much easier to see the outside of this passageway. I put compressed air gun against the outside hole and tried to plug the plug-well hole with my finger to see there was any leakage. I couldn't find any. I still get a very occasional drip out the hole and credit it to a slight porous point that allows the coolant to escape. While it used to leak after every ride (a drop or three), now its so rare I don't remember the last time it happened.
So to Miloarrow's post: is your plug getting fouled? After looking closely at this, I don't see how a pourous-casting leak, like I believe I have, would allow coolant into your cylinder to foul the plug. My bike has pretty much ran well and this leak didn't cause and poor performance that I've identified.
Old 10-28-2011 | 05:52 PM
linkin5's Avatar
MILOARROW your bike has more than one issue and that is why it is hard to diagnose. Electrical as in you speedo reset, and then and issue with a leak that could be from a porous casting and I dought it's fouling your plug, I'll bet that will be traced to your electrical issue.
Old 02-12-2018 | 01:02 PM
JaMan's Avatar
Scott, did you ever figure out what caused the slight drip of coolant? I noticed the same thing recently. Thanks!
Old 02-12-2018 | 02:15 PM
Abramsgunner's Avatar
Me too... just s drop now and again... I haven't really worried about it enough to spend any energy finding it, but enquiring minds want to know.
Old 02-12-2018 | 04:04 PM
Holy thread revival, Batman!
The best I can tell is that the head casting is a little porous. The other thing is that coolant could be dripping into the spark plug well from a radiator or hose, but in all my examination I found no evidence of this. Mine has not dripped in a long time.
Old 02-13-2018 | 11:43 AM
JaMan's Avatar
Thanks Scott!
Green hornet
10-18-2011 03:38 AM
Green hornet
09-16-2011 02:10 AM
Derosian
Ninja 250R
02-06-2008 09:20 PM
Blackhawk2k7
Ninja 500R
11-19-2007 04:48 AM
Quick Reply: Coolant Leak from Weep Hole below Thermostat Housing
