Cold Starting with a Fuel Primer
Old 03-26-2012, 05:31 PM
KLXHunter's Avatar
I've read differnt posts in the past but the primer bulb is installed right after the fuel shut off line then just goes to the gas port on the carb? Correct. I've seen smaller primer bulbs on snowblowers etc, and they have a seperate gas line and goes into the top of the carb. Help?! Pics? thanks
Old 03-26-2012, 07:05 PM
linkin5's Avatar
You could make it as complicated as you want it seems the OP chose not to.
Old 03-26-2012, 07:55 PM
KLXHunter's Avatar
so best just go directly from shut off valve to gas inlet of carb? worse case if you squeeze to much fuel it goes to overfill line?
chiadrum
08-30-2012 08:01 PM
KLXHunter
03-26-2012 05:48 PM
NDstructible
01-13-2009 09:01 PM
evil636
05-25-2006 05:41 AM
mrphone
02-05-2006 04:24 PM
Quick Reply: Cold Starting with a Fuel Primer
