Clutch slipping
Old 07-27-2018, 06:26 PM
RaceGass's Avatar
With the cvk carb I had a 40 pilot jet, fuel mixture screw was out 1-1 1/4 turns out, dj 2206 needle clip in the middle 3rd or 4 th groove from the top, slide drilled as per the instructions, largest main jet provided in that kit. No airbox lid, uni filter, fmf powerbomb header/two bros exhaust w quiet insert. All the free mods were done. Smog equipment removed n sealed off. I’m at sea level.
Higher elevations may require smaller 38 or stock 35 pilot jet depending on your area.
Old 07-28-2018, 10:43 AM
s10gto's Avatar
Originally Posted by Mick-F88
I used all six
How does the clutch pull feel?
Old 07-28-2018, 11:40 AM
Mick-F88's Avatar
The clutch pull is a bit harder, but not really a problem. It took a bit to get used to as it grabs hard with the new plates and springs not as gradual. I stalled it a few times turning at low speeds, I just have to get used to more throttle when starting up.
Old 07-29-2018, 04:14 AM
Klxster's Avatar
I can offer a 351 CVK setup for running with a lidless airbox - if you want to experience lidless performance, let me know..
Old 07-29-2018, 10:40 AM
Mick-F88's Avatar
Thanks, I will try that.
dan888
07-29-2017 10:53 AM
jworth94
05-20-2012 08:29 PM
stro
04-23-2012 02:55 PM
stro
01-09-2012 11:54 PM
RaceGass
06-16-2011 06:07 AM
Quick Reply: Clutch slipping
