Clutch Safety Switch?
RE: Clutch Safety Switch?
Cut the wires and twist them together. Once that's done, you may as well disable the kickstand switch too since it will be obsolete at that point as well. Assuming you haven't already done that, of course.
If you trace the kickstand wires up to underneath the seat you will find that you can disconnect them and then plug the pair into each other so you don't actually have to cut them. I cut my clutch wires up close to the connector so they would be safely out of the way under the headlight shroud.
mrtwelvevolts
08-06-2008 01:33 AM
outerextreme
05-22-2008 03:22 PM
