clutch install
Old 04-08-2013 | 06:27 PM
cegusman's Avatar
Default clutch install
Do you have to pull the right engine cover to change out the clutch or can it be done with just pulling the clutch cover?
Old 04-08-2013 | 08:47 PM
How are you going to hold the clutch from spinning? Holding the left side with a strap wrench (or however that's done)? If so, then I believe it can be done by just pulling the clutch cover. I pulled the right side cover and slipped a penny in the gears to keep motor from spinning when clutch removed. This also lets you check the oil pickup screen.
Old 04-08-2013 | 09:13 PM
did miine by just removing the clutch cover. I will have to look and see how i did it
Old 04-08-2013 | 09:14 PM
I think I just had the bike in gear. that was enough to hold the clutch from spinning.
Dan
Old 04-09-2013 | 12:30 AM
CousinLarry's Avatar
Yes - just pull cover. If you want, you can lay bike on it's side too and don't have to drain oil
To remove basket, put bike and gear and have someone hold the rear brake too for good measure.
Old 04-09-2013 | 02:15 AM
cegusman's Avatar
Do you really have to pull the basket? cant you just change the disc's?
Old 04-09-2013 | 02:25 AM
I don't think I pulled the basket, I just swapped the plates in the bike.
Old 04-09-2013 | 02:40 AM
cegusman's Avatar
Thats what I thought. Just pull the cover, then the 4-5 spring loaded bolts. Then swap them out.
Do I need any special tool?
Old 04-09-2013 | 02:52 AM
Nope, pretty straight forward.
youtube = good for a visual
Dan
Illking
07-30-2013 10:49 PM
RayCour
07-21-2010 10:35 PM
deej
10-02-2008 09:58 PM
JERSEY
04-23-2006 08:30 AM
Quick Reply: clutch install
