Clock resetting itself
I support the opinion on it being the battery.
I had bought a 'new' battery off a guy from Craigslist. Put it in my son's KLX, seemed to work, but didn't seem to last any longer than the 'old' battery (which was working, but didn't last long if it was stalled numerous times and had to be restarted.). One day, I went to start it and the Instruments would light up for .5 second to 1 second, then turn off. I had 12.8V on the battery, but once I turned the key to ON (not even trying to start it) and the voltage would drop to almost 0. I put the old battery back in, and it's been fine since (of course, this was after checking every fuse and every electrical connection I could find, and spraying the connectors with contact cleaner and then putting dielectric grease in every connection, thinking 'it couldn't possibly be the new battery, since it's new and is showing sufficient, although just slightly low, voltage.'
Hi Guys,
Thanks for the info.
The problem was dirty battery terminals, after cleaning them the clock hasn't reset itself.
However, during starting the F1 and overheat light come on and as soon as the engine starts, both go off. Although this isn't a problem (yet) it isn't correct, any ideas?
Another question, how are service codes erased from the memory?
Colin
Colin
