Christmas comes early.* You Tube clip added.*
Old 04-26-2008, 08:55 PM
mudjunkie's Avatar
Default RE: Christmas comes early.
did u mention somethin' 'bout a sound clip? I am curious to hear the pipe minus a quiet tip insert...do u like the sound w/o the quiet insert or is unbearingly loud?[:-]
  #32
Old 04-26-2008, 09:46 PM
WestOzKLX's Avatar
I've got the caryb off again to tweek it.
As soon as I get it on again I'll fire her up and record a clip for you.
IMHO the pipe isn't too loud. Sure it has some bark but no more than the local Harley riders.
HERE is something someone else posted.
  #33
Old 04-29-2008, 08:39 AM
WestOzKLX's Avatar
Added the You Tube clip. Click HERE.
She's still running a little rich with the air box lid on. I'll try it without it on the W/E.
Throttle response is great. No low down bog. IMHO the jetting isn't far from spot on.
  #34
Old 04-29-2008, 01:43 PM
sounds good man!!
  #35
Old 04-29-2008, 08:05 PM
That's got a good growl to it.
  #36
Old 04-30-2008, 02:19 AM
mudjunkie's Avatar
wooohooo...got my missing X-ring today and installed the 2 bros...had to remove the old gasket from the header pipe and measured the ID of it..it was 1.4-inches and the new mid-pipe OD was just over that, so I bought some high-heat gasket glue and put some on the end of the mid-pipe before inserting it into the head pipe. So now i am being a good boy and waiting the 24 hour cure time before firing it up...thanks for the clip..can't wait until tomorrow nite to hear it in person.I'm thinking the slip-on was made to go in the head-pipe minus the gasket from the measurements I took, but still felt the need for some sort of sealant, hence the gasket glue..it shouldn't leak and the glue is rated for 650F, so I think it'll be fine.
  #37
Old 04-30-2008, 02:26 AM
WestOzKLX's Avatar
Similar to what I did. 200km on the pipe now and no sign of a leak anywhere despite some tuff AUSSIE punishment. Nearly got those whoops whipped.[sm=gears.gif]
I'm really happy with it so far.
  #38
Old 04-30-2008, 09:25 PM
mudjunkie's Avatar
WOW..this pipe is a lot louder than my drilled stock exhaust. I expected a bit of a change but WOW...I think i like it, but have not had it for a ride yet to know for sure. It's pouring rain outside today and doesn't look like it will clear up until Saturday. My bike inspection is up, so i hope to get it inspected by the week-end so i can take it out for a good run..don't really want to chance a ride on it before inspected as I am sure the loudness of the new pipe will draw unwanted attention, but if it stops raining, I will likely succomb to my urges and sneak it out for a short run.
Is anyone else running without an insert in the two brothers? And do you find it draws attention? It sounds awesome, but loud.
  #39
Old 05-01-2008, 02:00 AM
SherpaDude's Avatar
I'll have my Two Brothers installed and my carb rejetted in about a week. I plan on using the P3 power tip, though, since I'll be using the bike as an occasional commuter. Can't wait for the the sound, though.
Jeff
cegusman
06-15-2011 06:49 PM
mandark
11-24-2008 01:40 PM
vlodpg
11-21-2007 02:21 AM
Marty
05-23-2006 06:08 PM
deej
02-19-2006 07:11 AM
Quick Reply: Christmas comes early.* You Tube clip added.*
