Chopping Rear Fender Question...
Thinking about chopping off the rear fender on my 09 right below the license plate, what should I use an angle grinder????? Any tips, tricks and suggestions are welcome.
RJ
RJ
Dremel tool with a cutting disc! That plastic gets hot and melts....if if melts too bad you won't have a clean cut. Use sandpaper to clean up the rough stuff.....that's your mission, now good luck! ;P
I searched, but I guess not enough. Here's a link to some pics.
https://www.kawasakiforums.com/forum...ed+rear+fender
