Chinese powerbomb
Old 12-18-2019, 12:53 AM
Klxster's Avatar
Yep, you simply remove the spring.. You can go ahead and remove it now if you want.. The spring holds the weights closed during startup RPM's, but allows them to expand - and stay expanded - at RPM's above startup. Removing the spring simply allows the weights to expand AT startup RPM.. ( Expanded weights = deactivation )..
This MUST be done as part of the MCM - as otherwise your bike will not start when warm/hot. This is due to the MCM retiming the exhaust cam 10 degrees from standard - thus "throwing off" the KACR timing severely enough to cause warm/hot starting issues..
Old 12-18-2019, 01:01 AM
Rickybobby2's Avatar
This MUST be done as part of the MCM - as otherwise your bike will not start when warm/hot. This is due to the MCM retiming the exhaust cam 10 degrees - thus "throwing off" the KACR timing severely enough to cause warm/hot starting issues..
I really appreciate your help. This forum has been extremely helpful to me as I have added modifications to my bike.
Thank you!!!
Kjurinek1
03-31-2019 04:09 AM
punkenduro09
07-12-2013 10:15 PM
Warren3000
07-04-2013 10:49 AM
ducatiss750
09-04-2009 12:20 AM
2k1w=no$
02-11-2009 06:19 AM
Quick Reply: Chinese powerbomb
