Checked my valves yesterday
Old 10-29-2007 | 04:24 PM
Davebert's Avatar
Default Checked my valves yesterday
I finally got around to checking the valves on my wifes 2006 KLX250S at 3,567 miles and here is what I got. Intakes look good, left exhaust at minimum spec and right exhaust at .001 below minimum spec. Time to order a shim kit. Where is the best place to get one again? HotCams or something like that?
Thanks,
db
Old 10-29-2007 | 07:59 PM
Davebert's Avatar
Default RE: Checked my valves yesterday
Ok, so I need the 7.48mm shims. Is $65.00 for a HotCams shim kit about as cheap as it gets?
Thanks,
db
Old 10-29-2007 | 08:44 PM
LearjetMinako's Avatar
Yep, thats correct. I went through the same thing. Had everything I needed just to find, no adjustment was needed. All valves clearances were dead center of spec. Well, at least I'll have the Hot Cams shims for the next time it needs adjustment.
Borg
04-26-2012 10:54 PM
jengreen
Oncycles.com Motorcycle Riders Mall
04-03-2009 09:42 PM
RudyH
Ninja 250R
08-18-2008 01:07 PM
HeavyFuel
11-13-2007 11:48 AM
