cheapo fork support/brace for trailering
Old 11-27-2012, 04:21 PM
Originally Posted by deej
I am finding more and more stuff on Amazon, and it has become my first place to look for anything, from stuff for work to things for home. It also seems that there is nearly nothing I can't find on the site.
Yup, can find just about anything on Amazon...
Amazon.com: Passion Natural Water-Based Lubricant - 55 Gallon: Health & Personal Care Amazon.com: Passion Natural Water-Based Lubricant - 55 Gallon: Health & Personal Care
  #32
Old 11-28-2012, 12:05 AM
ol'klx-er's Avatar
Originally Posted by IDRIDR
55 gallons of PASSION Lube!! Lifetime supply or one WILD weekend!
WOW, you must have quite the "parties" in your neck of the woods
  #33
Old 11-28-2012, 01:11 AM
I would not trust the friction tie downs unless the bike was in a truck bed, or somewhere contained. On any thing the bike can fall out of, like a hitch rack, or loaded close to the edge of a low trailer, ratchet straps are the way to go. I think its irresponsible to have the bike in a situation that, if only one strap broke or came loose, the bike could fall off into traffic.
I don't think it is too harmful to compress the suspension while hauling, but I also don't think you can get the bike cinched down good unless you have some sort of brace. I used to use a couple pieces of wood between the wheels and fenders, but a friend showed me ,what I think is a better way. It is a small wooden pedestal that is slightly shorter than the distance between the skid-plate and my hitch carrier. You position the pedestal under the bike and as you strap it down, the suspension is compressed slightly, enough to plant the tires to the rack, and then when the skid-plate comes into contact with the pedestal you can tighten until it's rock solid. This requires ratchet straps, but like I said , I would never think of using friction straps on the hitch carrier. I use the soft loop style strap so you aren't scratching up your bars or forks. When my bike is loaded, you cant wiggle the bike without wiggling the truck.
I have nifty chain/hook that I can lean the bike on while i position my pedestal and straps. Roll bike up onto carrier and hook chain to the footpeg.
lean the bike over and let the chain hold it while you situate you pedestal / straps.
Soft loop straps around the fork tubes.
Tighten the **** out of your ratchet straps, and add two more in the rear to help center the the tension on the pedestal, and serve as backups in case a strap breaks. ( I think that the straps in the back could be the friction type as the front straps do most of the work.)
This is how I do it I'd rather err on the side of caution.
Dan
Bike is rock solid.
  #34
Old 11-28-2012, 02:35 PM
Pauls2ndblessing's Avatar
Dan888,
That looks like one of the better ideas I've seen/heard using that pedestal. Thanks for sharing man, if I hadn't of already ordered a fork brace yesterday I'd build on of those. I think I still may build on for my fiance's bike.
Paul
  #35
Old 11-28-2012, 03:28 PM
Yes, Dan did good work there. I like the chain thing too. That guy is a thinker.
And the support could double and a short little stool, or a bike stand with a little more height.
  #36
Old 11-29-2012, 12:03 AM
Even a broken clock is right twice a day.
  #37
Old 11-29-2012, 04:13 AM
drm's Avatar
drm
drm is offline
Time to show off those new plastics Dan...
  #38
Old 11-29-2012, 08:55 PM
Brieninsac's Avatar
Well I decided to go ahead and buy one. I got this one for $14 on eBay with free shipping. For that price you can't go wrong.
  #39
Old 11-29-2012, 09:42 PM
I ordered one from amazon for 17... 2 days ago and it still hasn't shipped
  #40
Old 11-29-2012, 10:43 PM
I'll get them on there, I'm being a little overprotective of them
Quick Reply: cheapo fork support/brace for trailering
