Cheap, small, gear indicator
is there something small that I can install to let me know what gear I am in? I don't need something like the trailtech because I already have gauges for RPMs and speed etc.
I doubt you will find any cheap gear indicator, it takes too much to "know" what gear it is in.
Best way is feel. If it's bogging downshift at least one, usually two gears. If it is reved out some, and not pulling very hard upshift. That's the way it's done on off road bikes. Who cares what gear as long as it is pulling. At a stop, look for the flash of the neutral light to know you've gone into first.
Start in 1 and when you shift, just add one in your head, do that if it is that important to you. When your downshifting and you hit first, you can tell with your foot it ain't go'in any lower! ... and then you start adding 1 again, it's not that hard.
the only reason I wanted one was because I like to start in 2nd. I now downshift until I hear I am in first, then click one time back up to second. would be nice to know when I hit second.
it would also be nice to know when I am in 6th instead of trying to shift up one last time.
Curious as to what gearing you're running for second gear starts. You must have awfully low front/rear sprocket setup. I have 14/50 gearing, and I wouldn't start off in second gear as a matter or routine. The KLX250 clutch is decent but not that robust.
On your gear indicator, I think the most annoying point in the gear range is that 6th gear deal where you feel the need to shift one more time when you're in sixth. However, since you have a Trailtech...I do too...you get used to the RPM to speed factor to know when you're in sixth. On the pavement where this is the only time it really matters, a quick glance down at my speed and RPM on my Trailtech tells me when I'm in sixth. It takes about the same time and concentration to do this as it would to see an indicator number.
I swear I have always been searching for one more gear on every bike I've ever owned. Always seemed like there should be another.
Gotta tell you, I rode a used Hercules 250GS (Sachs engine) that had a seven speed. That was really cool. No idea why they don't bother to do 7 speeds in dual sports. It would allow great gear spread without needing sprocket swaps. Other great possibility would be a dual range.
