Changing tires, get new chain? Sprockets?
Old 10-15-2011, 03:22 PM
Stashu's Avatar
Default Changing tires, get new chain? Sprockets?
Hi all!
Bike: 2006 KLX 250 w/430 miles
I just received my tires, tubes and rim strips from Dennis Kirk, i went with IRC brand GP-1. 4.60x18 rear-----3.00x21 front
For ease of use----It's been a while "30+ years" since I replaced a cycle tire, Talcum powder and/or Dawn? or any newer methods?
Question: as long as the rear tire is off, the sprockets are OEM and I am thinking of going lower on the front sprocket to 13t. Good idea? I really do not care about speed, I am interested in good/better pickup. Or is going to a larger rear sprocket better? And Should I get a new chain?---having only 430 miles on the OEM chain I am curious if I need a new one?
Where is a good place to get a new sprocket and chain?? Dennis Kirk? EBay?
Thanks for any input!!
Stashu
Old 10-15-2011, 04:00 PM
wildcard's Avatar
Originally Posted by Stashu
Hi all!
Stashu
As long as you keep the same pitch with the new sprocket i woulndn't bother replacing the chain with only 430 miles on it.
Old 10-15-2011, 04:11 PM
Stashu's Avatar
Thanks for the reply!
So if I went with a 13 tooth front I can use the same chain BUT remove one link and as always replace the master link.
thanks
Stash
Old 10-15-2011, 04:38 PM
I would continue using the stock chain. You should not have to remove a link from it, you will have to adjust the chain slack, but there is enough adjustment room to accommodate the 13 t. I ran mine like this until I went back to the 14 t with the 351 big bore.
Changing tires I use talcum powder and windex, but yeah pretty much the same.
Dan
Old 10-15-2011, 04:58 PM
Stashu's Avatar
Thanks for the reply.. good to know I do not have to take a link out.
I've seen 13t sprockets on Ebay "RENTHAL FRONT Sprocket" part #438-520-13
for about 20.00 or so.
Better than stock Kawa OEM Sprocket???
Thanks
Stash
Old 10-15-2011, 07:58 PM
Blackheart58's Avatar
I prefer going up a couple of teeth on the rear instead of dropping a tooth up front, when I'm looking for more pull. I think the drivetrain lasts a bit longer (chain and front sprocket) when you don't have such a tight radius of a smaller front sprocket. However, in the long run, it's probably cheaper to go to a smaller sprocket in spite of the small increase in wear rate.
But, if you're going to change the chain at 430 miles, can I have your old one?
Old 10-17-2011, 01:39 AM
A 2006 with 430 miles???!!! Really? Did you miss a zero? Nice find!
picked up my 2006 one year ago with 3K miles. It was sweet and stock. I thought I picked up the lowest mileage 2006 around
then bumped up the stock 14/42 to a 49 rear and 13 front and needed a new chain for length. Now running 13, 14, or 15F with 49R (this weekend was with the 15/49 pretty close to 13/42). Yesterday, I wish the 14 was on. It was steep and we were fully loaded for a weekend DS ride; put on over 200 miles in the desert off road.
Old 10-17-2011, 02:16 AM
turnsleft's Avatar
My 09 has 6474 miles on the stock chain with about the last 2000 being a 351.
Most of the time I run 12X42 with 14X42 for more hiway. Last ride I put a 15 on just to see the diff. No more 14 for me. When I get new it will be 12&15x42.
I ran Kanda "Washougal Sticky" front and back but just went with a Kenda "Track Master"120X100 out back to see if the wear was any different.
Old 10-17-2011, 04:02 AM
ol'klx-er's Avatar
12 tooth for an '09? Details?
Old 10-17-2011, 08:32 AM
09'Kawi250s's Avatar
im gonna run 14/49 here shortly
Quick Reply: Changing tires, get new chain? Sprockets?
