Changing to a 13 t front
#32
the other day my shoelaces both ended up right into that chainsaver plastic cover
a hair away from getting sucked in and I notice that on the freeway
was scared it would pull my boot off or something
one in a millon shot getting both tips of my laces somehow sucked in
#33
shoe laces are dangerous..i triple knot it and have my pants over it....once my shoe lace got sucked in and stuck...almost tipped over to the left, but quickly accelerated briefly enough to straighten, pull over and lean right to get the lace out...
#34
or worse the loops get stuck on the peg when coming to a stop, and you realize the leg you rest on is not going to touch the floor
my laces had to bee 14 inches long when they came loose
I had my foot as far over as I could on the peg and the freeway wind blew the lace tips directly into the sprocket
#35
Getting pants, shoestrings, and other clothing items hung up in the bike's components may not be a common occurrence, but it can happen with some nasty results.
#37
Shoe laces! My bike ate one last summer. I was wearing army parade boots (with steel toes). While riding I heard a "tack" and felt something on my foot. I looked down to discover that a piece of my left shoe lace was gone. I was lucky it put spaghetti style laces a couple days ago on those boots. If I had put the large ones, I guess something bad could have happened.
#38
I was out on my KLX yesterday with the wife on the back and found the first decent bit of tarmac to open it up,, 130KM/PH in 6th when the rev limiter cut in,, i always assumed it was standard , but going to count me sprocket teeth now,,
Cheers
Cheers
#39
I was out on my KLX yesterday with the 250lbs wife on the back cruising down the freeway at a steady 150KM/PH in 6th, passing semis on one wheel...
Than my mother woke me up!
Good morning guys
Good morning guys
#40
but you know the speedo is way off to a gps
so 130kmh really isnt that big of a deal
hitting the limiter is you must have different sprockets and may not want to drive it at those speeds
I installed that electronic speedo calibrator so now mine is dead on with gps
so thats why my numbers seem lower then you think, but its the true speed
when im at 104kmh my tach is 7000 thats our highway speeds here
all I did was put in a 15t
when I was 14t my tach was 7800 at the same highway speeds
but I cant go much faster then that maybe up to 117 never had the chance to check yet nor do I really care
I dont ride much at high speeds but when I do I just wanted lower rps
