Chain stretch
Old 08-03-2007 | 02:20 AM
jaylaudeman's Avatar
Default Chain stretch
I just bought my first bike a 2007 KLX250s I was wanting to know how often you have to adjust for chain stretch. I have 160 miles on it now and noticed its pretty stretched now and that I need to tighten it. Do they stretch a lot during the break in period, and after I moved the adjuster on the wheel all the way past would you then take a link out of the chain to make it shorter and shorten the adjuster?
Old 08-03-2007 | 02:29 AM
bryantjt's Avatar
Default RE: Chain stretch
The first few hundred miles the chain does stretch. Try to check it every 2-300 miles till you break 1000. I have 5200 miles on mine on the original chain, and have gone to a 13 tooth front sprocket (from the stock 14) and I think I'm on adjuster mark 5.
Old 08-03-2007 | 02:31 AM
Bad Bear's Avatar
I don't think it will ever stretch that far I have 2200 miles on mine and have only adjusted it one time..... it is supposed to be loose it should come about 1/4" from the top of the chain guard on the side stand....These bikes have a lot of travel so it needs slack for that and the more the rider weighs the more it needs
Old 08-03-2007 | 06:11 AM
I've bumped mine 8 times in as many months, maybe cheap chains stretch more.
Old 08-03-2007 | 06:14 AM
It is a DID chain??
Old 08-07-2007 | 07:11 PM
JB1's Avatar
JB1
ORIGINAL: jaylaudeman
Dont adjust it too tight...they are suppose to have some slop
gotrice
02-23-2010 11:43 AM
Marty
10-05-2006 07:50 PM
Banzai
10-05-2005 10:16 PM
Kowi6r21
01-23-2005 03:18 AM
