chain and sprockets
chain and sprockets
hey guys,
im up for a new chain and sprockets
long to spend around the $200aud for everything(i will install)
what brand etc have worked, i have heard about the harded style lasting around 60 000 - 100 000 ks, as i am a cheapy i would like them to last a long time.
i am planing to run 14-46 sprockets, thoughts on this, im running 14-49 and would like some more road friendly gearing.
thanks in advance
thanks in advance
I used a 108 link D.I.D. premium chain (~$100) and a 46 tooth JT Sprocket rear (~$35).
14/46 gearing works well. I run about 500RPM more in top gear for any given road speed (at least in the mid-range ) and have more power for sand and hard starts off road.
Buy a 13 and 15 tooth front and you can run stock ratios to really low offroad gearing.
whent dow to my local bike store, came up with this
jt harded steel sprockets
rk chain
all up 180aud
thoughts
and for every one who is running 14/46, at 80kph what rpm do are you at
rk chain
all up 180aud
thoughts
chaingang sprockets will last forever and he has chains too
http://www.chaingang.com.au/shop/ind...ewDoc&docId=24
well i ended up going with this from www.ballards.cc.
14-46 combo, using supersprox
DID chain
all up it came to 189aud, posted
DID chain
If you guys had to say,
Best combo for strictly offroad:?
Best combo for strictly on road:?
Best combo for mixture of both:?
Best for mostly on road with a little bit of off road:?
Basically I want to know what to run if I want the bike to be as quick as possible out of the hole and then what to run if I want good top end speed. I have a 351 kit on the way so keep that in mind.
csaba1589
03-29-2010 03:18 AM
95zx6rGuy
09-07-2007 04:27 PM
95zx6rGuy
09-07-2007 04:27 PM
