Chain snapped going uphill
Old 06-18-2006 | 06:02 PM
Default RE: Chain snapped going uphill
See here, "fact 4" and "fact 5":
http://www.quality-cycle.com/truth_a...cle_chains.htm
Old 06-18-2006 | 06:17 PM
ORIGINAL: Nobrakes
All the way to the bottom of that page it shows the wrong way and the right way to oil a chain, look close at the "right way" picture and you can see chain lube getting all over the tire, yea that's the right way all right.
Old 06-18-2006 | 07:00 PM
I tend to have a problem with those aerosol lubes anyway. I bought some of the "chain wax" stuff and I've been very disappointed - it's messy and doesn't seem to do a very good job at lubrication, IMO. I find that a good lubing with the manual's recommended 90 weight oil works the best. A single small drop on each "o-ring" and one in the middle works perfectly. You only get oil sling if you use too much.
Old 06-18-2006 | 09:52 PM
GreenOne's Avatar
ORIGINAL: Nobrakes
Good information...Thank you
Old 06-19-2006 | 03:56 PM
dazjr's Avatar
It must be true, the page recommends the same chain lube that I use. I lube my chain about every two weeks anyway because I ride in the river all the time. I just might save myself some money and get a non-sealed chain. Thanks for the info.
Old 06-19-2006 | 05:34 PM
incabiker's Avatar
Yup,
I think that I am going to get just a normal old chain, no o-ring or x-ring. Seems fine to me.
Old 06-19-2006 | 06:50 PM
I can't remember what the brand is but I bought a container of chain lube and o-ring conditioner, its in a plastic shampoo type bottle, it really works good, but I tend to not lube very often, and tyy to keep the chain clean and dry after I wash it. It looks good. In fact for 1850 miles it looks basically brand new.
Old 06-19-2006 | 09:09 PM
That's really all you should need to do for an "o" or "x" ring chain. The o-rings keep the lube where its suppose to be. A little lube to keep the o-ring seals good and that's all you need. It would be important to not direct too much pressure wash on your o-ring chain, though, since the high pressure could defeat the o-ring seal and wash out the grease.
There's a lot more maintenance for a non-o-ring chain, so that's the downside but they can also last a long time as long as they are cleaned frequently and well maintained.
Old 06-19-2006 | 09:44 PM
incabiker's Avatar
Let me ask this,
What is the proper way to clean an O-Ring. I remember I put some of the PJ-1 stuff on the chain then went for a ride. After I got back I noticed that my chain was just nasty because the dust and grit had been kicked up on the chain and was glued to the chain because of the PJ-1 lube. I cleaned it with soap and water to no avail, it only got a little off. What would be the proper way to remove all that crap from the chain? How often do You have to lube the chain? I was doing mine about once every 2 rides. Guess I was going way overboard on that huh lol. But wonder why it cracked? Maybe it was just a faulty chain that was under too much pressure going up the hill and it couldn't take the load.
davehayward1
Z750
09-04-2009 10:26 PM
Violet_Vixen
08-31-2005 12:17 AM
Violet_Vixen
08-10-2005 01:52 PM
c10
03-17-2005 02:12 AM
Quick Reply: Chain snapped going uphill
