chain replacement
removing stock klx250 chain and installing new...any help or instructions?...tools i'll need?...
local shop quoted me $120 (1.5 hours) to replace both sprockets and chain....i can do the sprockets myself, but i need the chain on too....my other option is cut the stock off and replace both sprockets...some how get the bike to the shop to install just the chain only...chain is kind of important and didn't want to have a major failure on such an important part on the motorcycle...
dealer shop wanted $150 (1.5 hours) to replace both sprockets and chain
Easy but requires some tools.
- Removal is simple. Just grind the heads off 2 adjacent pins and punch them out to release the link.
- Installation requires a vice/clamp/vicegrips to press-fit the plate onto the pins. Then it depends on what type of master link you have. A clip-type requires just a set of needle-nose pliers. A rivet-type requires a chain-pin knurler, or a punch and anvil.
Specialized chain tools are also available.
Really? Standard O-ring or X-ring chains with a standard master link are removable and replacable on the side of the trail. A little extra love to pop the sideplate off of the master link after you pop the clip off and again to replace it.
It will be harder to replace the sprockets than to replace the chain.
Easiest: definitely anything with a clip-link, like the DID. Clip inks can be bought separately too. **Beware** clips can come off but I have only seen it happen at very high speeds (>250kmh) that the KLX won't be able to get anywhere near.
Standard vs 0-ring: It's up to you. Price & less friction are the two big advantages of standard. Low-maintenance is the advantage of 0-ring. Again the little KLX doesn't put a lot of stress on a chain. I would never run a standard chain on a high-horsepower bike but I have one on my KLX and it's fine.
found it with master link, but doesn't say if it's a clip or rivet...
DID 520VX2GB-106 Gold X-Ring Chain with Connecting Link : Amazon.com : Automotive
looks like they sell the clip link for the did vx2 for $8
Motorcycle chain rivet link
Pretty sure the stock Kawi chain uses a clip style master link. Keep that as a spare in with your tools out on the trail. Youtube vids are the way to go. When you instal the clip that holds the master link together , install it so it's closed end is facing the direction the chain travels. This will tend to keep it in place.
Dan
Dan
I must not be following something here... why would a chain need to be cut off?
To get my chain off I simply loosen the rear wheel and slide it forward. I would think you'd need to do that to replace the sprockets anyway...
