Carburetor Slide need help!
after i took it out i relized it had a hole in bottom and am now not sure which way it goes in. i'm guess it goes toward the air box side of the carburetor, and is this the hole that needs to be drilled out?
RE: Carburetor Slide need help!
OK i should of provided some more information but I have a 07' Klx250h and the slide is simmilar to that one doesnt have the white pice or the hole on the back side like that but i can put itback in either way. It is an oem slide CVK 34
