Carb vacuum diaphragm expanded
Old 04-15-2013 | 06:46 AM
ITNANTI's Avatar
Default Carb vacuum diaphragm expanded
What do I do to get it to fit back together. It expanded and won't fit the groove. Does anyone know any tricks. A new one is 100$.
Old 04-15-2013 | 11:31 AM
MaximusPrime's Avatar
Hot water is supposed to help keep it from expanding, don't know if it will shrink it, worth a shot.
Hope you don't have to buy a new one.
Old 04-15-2013 | 01:15 PM
DYNOBOB's Avatar
Just leave it sitting for an hour, it will shrink. Don't get carb/brake cleaner on it.
Old 04-15-2013 | 03:01 PM
ITNANTI's Avatar
Thanks dynobob. I let it sit over night. In the morning it fit perfectly.
Old 04-15-2013 | 05:00 PM
Good to hear it worked for you.
I've used the HOT water trick several times. Works like a charm. It's odd, but HOT water shrinks and stiffens the diaphragm.
Old 04-16-2013 | 01:00 AM
I'm guessing the formula of nitrile in the diaphragm is designed to work better warm than cold due to the environment it consistently operates in...behind a hot motor.
Old 04-16-2013 | 04:13 PM
ITNANTI's Avatar
After cursing at an expanded diaphragm and the thought of a 100$ mistake, I calmed down when I read the hot water trick. I stuck it in a cup for about 15 minutes and then let it sit over night. It was back to normal in the morning.
ezrollin
Ninja ZX-7R
02-09-2008 11:14 PM
klx250s_rider
07-02-2007 04:19 PM
klxstiffler
07-05-2006 08:24 PM
badvwg60
05-20-2006 11:18 PM
pimpswithmints
Joke section!
22
03-20-2006 07:11 AM
Quick Reply: Carb vacuum diaphragm expanded
