Carb tuning question
Old 06-14-2010 | 12:26 AM
Juggernaut's Avatar
Default Carb tuning question
Recently bought a '09 KLX250s and doing the typical mods: slip-on, Dynojet, K&N, etc. Did the re-jet, but now the bike has a little bit of a bog up to 4500-5000 rpm. It does great above 5k, thinking it's too rich up until that point? Followed the DJ instructions. When it comes to carbs I am a complete newbie as far as tuning or troubleshooting. Recommendations for what to change to clear it up? thx!
Ryan
Old 06-14-2010 | 05:20 AM
slippery750's Avatar
Yes, at that rpm range the needle has everything to do with mixture. If its running rich you need to move the needle E clip up a notch, possibly two. This moves the needle further down into the main jet letting less fuel out to be atomized. Go with one notch if the bog is not too bad.
Old 06-15-2010 | 02:51 AM
lcpl0331's Avatar
Did you take out the snorkel yet? You might try getting more air in there first before you go back into the carb. It's most likely the needle like he said but if it's a small bog more air just might do it.
Old 06-16-2010 | 12:25 AM
Juggernaut's Avatar
Yep, snorkel is out. Wanted to try it before I yanked that carb back out. With the snorkel in, it changes to having some surging probs while at a constant RPM. I will work with the needle a bit and see if that will fix it. Thanks!
Ryan
Old 06-16-2010 | 12:28 AM
jacksonriding7's Avatar
From: In North Western Jersey, but from Jackson, WY Originally
I would think you dont need to yank the carb all the way out for the needle? just get to the 4 screws on top to pull the cap and you should be able to do the needle adjustment and leave most everything carb wise still connected.
Old 06-16-2010 | 01:33 AM
Juggernaut's Avatar
Yeah, I can probably do it that way. Will just have to make sure the needle gets in the seat properly.
Ryan
Old 06-16-2010 | 01:59 AM
Ryan
If you can manage to have the slide down and drop the needle in with a pair of needle nose, it should line it up real easy and give you confidence it went down. I read somewhere recently to have the diaphram in the up position when installing it recently, but I cant see it making any difference as long as the rubber rim is seated correctly in the small lip it goes in. I've done 2 other CV carbs that way.
kyrral
05-05-2013 03:56 PM
WestOzKLX
04-25-2010 01:17 PM
SavageKen
09-19-2008 02:12 PM
WestOzKLX
09-18-2008 10:46 PM
willysan
04-20-2008 03:44 PM
