Carb problem?
Ride on
Brewster
That's pretty much the normal way a bike works when the pilot circuit is clogged. Runs on choke using the choke circuit as an idle circuit. Turn off the choke, not enough fuel gets through so it shuts down.
Clean the carb. pull the pilot jet, hopefully that's where your clog is. If it's inside the body in the passage it ain't gonna be easy to clean.
