carb mod / hesitation
Old 07-09-2007, 01:43 AM
acgill's Avatar
Default carb mod / hesitation
This afternoon I removed the smog stuff, did the 3/8 crank case vent, added the kdx snorkel and carb mods.
As far as the carb goes I went with the N1tc needle on the second notch, 125 main jet, 40 pilot jet, and moved the screw out 2 turns.
The bike seems a lot stronger but there is a slight hesitation or bog early in acceleration. What do I need to do to fix that? Adjust the needle, move screw out 2.5 turns? thanks for the help
Old 07-09-2007, 01:44 AM
acgill's Avatar
Default RE: carb mod / hesitation
Also, I started to drill out the slide to 7/64, but the hole already seemed that big. the 7/64 bit went right in. Whats up with that?
Old 07-09-2007, 01:56 AM
FM_Thumper's Avatar
ORIGINAL: acgill
Is the bike new or did you get it used? If used, maybe someone already did the mod?
If the bike is new, are you looking at the correct hole? The slide is the smaller hole towards the outer part. Not the bigger hole in the center.
Old 07-09-2007, 05:03 AM
vurtle's Avatar
When you say you moved thescrew two rotations out, do you mean from the seated position or from the position it was already in from the factory. If you have a 35 pilot jet and you are currently at two rotations out from seated, you should go another half turn or maybe even go with 2.75 turns out.
Old 07-09-2007, 11:22 AM
acgill's Avatar
THe bike is new, and I was looking at the outer hole in the slide. I am running a 40 pilot and I am 2 turns out from the seated position.
Old 07-09-2007, 11:32 AM
my bike was rich... so i turned the a/f screw in to 2 turns out, and took the air box lid off, and not its bogging down in low rpms.... when you first start... i think its gettin to much air... gonna try to put the air box lid back on......
Old 07-09-2007, 04:24 PM
JB1's Avatar
JB1
JB1 is offline
ORIGINAL: acgill
Your trying to drill the wrong hole...its the top hole not the center hole.
Before drilling:
After drilling
Did you plug ALL the ports when you removed the smog?
Also make sure when you adjust the fuel/air screw....2 turns means 360deg not 180deg so if your watching the slot turn its like 4 if you will....check that too.
Old 07-09-2007, 04:45 PM
acgill's Avatar
I plugged all of the smog openings with vacuum plugs. I tried to drill the top hole, not the middle one. I will check the screw and see if I screwed up going out two half turns instead of two full turns, but I am pretty sure I did it right
Old 07-09-2007, 05:55 PM
ZX1100F1's Avatar
Also make sure that you grabbed the right size drill bit and not the 3/32", bits that small are impossible to read so I find myself relying on their location in the case.
Old 07-09-2007, 06:30 PM
JB1's Avatar
JB1
JB1 is offline
I bought a new bit when I drilled mine just to make sure it was correct
Quick Reply: carb mod / hesitation
