Carb is leaking...
This bike is a new '09 that I picked up only 2 weeks ago. Presumably it had been sitting on the dealers floor for a good year or more. Anything else I should worry about with a bike sitting that long? It only had 6 miles on the odometer when I got it.
Thanks again!
Thanks again!
Me personally, I would not do anything to the bike except take it back to the dealer. I'm all for working on my own bikes but if you just bought it, it should be under warranty. Let the dealer correct their wrong and return it to how it should be.
I've done this with my KLR650's in the past that sat for too long. Pull the fuel line off the petcock. Drain the fuel float bowl at that nipple and drain screw...get a hose on that nipple. Now get some Chemtool B12 or other carb cleaner than you can spray or pour into the carb's fuel line until it fills up into the top of the fuel line. Crack open the drain screw just a little to insure that some cleaner is coming out that drain screw. Close that drain screw again and fill up that fuel line hose again all the way to the top. Let it sit. Before restarting, drain that cleaner from the fuel float bowl drain screw and reconnect the fuel line. Turn on the fuel petcock and see how it goes. You might get lucky.
