Can anyone tell me if my compression releaser is broke?! (video)
Old 06-26-2009, 11:11 PM
armycopter's Avatar
Sweet man. I'm glad this had a happy ending!
  #52
Old 06-26-2009, 11:26 PM
neilaction's Avatar
Well done.
Good news.
  #53
Old 06-26-2009, 11:37 PM
CousinLarry's Avatar
And I filed/sanded those fish gill marks down on the piston.. Extra displacement!!! hahaa
So now I'm calling it a KLX351.5
PS - the valve did not need lapping, I poured rubbing alcohol int the exhaust port and it didn't leak a bit. Thanks for that tip Brewster
  #54
Old 06-26-2009, 11:56 PM
Here's what I made
Worked perfect
Used big C-clamp.. Put the head on a table with a folded up rag underneath that valve so it was right up on it.
Then used the clamp to clamp the whole thing to the table, and was able to just slide the keepers right in the hole.
One shot, one kill
  #55
Old 06-27-2009, 04:10 AM
Xplosivo1's Avatar
very creative, it's always nice when you can make you own tool to ease the job along. Let us know how the gaskacinch works out.
  #56
Old 06-27-2009, 04:32 AM
I will do that.
On a side note - does anyone know what the stock shim thickness is?? Or am I'm blind for not seeing it in the manual?
I am within spec on all, but the new valve is just barely.. The other exhaust is .15, and this one is .229..
Both intakes are at .152
The bike runs great though. Re-torqued the head, and went for a short spin. Took up to highway speeds, all seems well. I hope the gasgacinch does it's duty and that's the last time changing that farkin head gasket!
I guess the good part is I'm a pro at it now!
So should I re-shim that new exhaust valve, or just keep checking it periodically and swap it if it goes out of spec? I see in the manual how to select the new shim, just don't know what the current one is.
  #57
Old 06-27-2009, 10:36 AM
Brewster's Avatar
Normally the valve clearances close up with use so your .229 is ok and it is within the specs. It is the intake valves that we have the problem with. They seem to loose clearance at a much greater rate than the exhaust valves.
Ride on
Brewster
  #58
Old 06-27-2009, 11:49 AM
Cool... Good to hear Thanks again Brewster!
CousinLarry
12-22-2010 02:33 AM
sman
06-26-2010 02:47 AM
noimad1
KX250 & KX250F
48
02-10-2008 07:09 AM
Dsking
05-04-2006 02:54 AM
jmkhet
04-30-2006 01:46 AM
Quick Reply: Can anyone tell me if my compression releaser is broke?! (video)
