Call me stupid...
Call me stupid...
As the majority here know, I've been studying my mpg. Well today I decided to check my air pressure, 25ish in the front...15 in the rear, it all makes sense, rear end is loose in the turns and my mpg sucks....god tire pressure, so obvious.
Of course you're stupid. Everyone knows that God tire pressure is better than earthly air pressure any day.
What does the manual suggest as tire pressures for the SF? 25 sounds high for the front. But your average is great. 25 + 15 = 40 / 2 = 20.
'09 S pressures are 21F 21R (25R with passenger).
A LOT depends on the kind of riding you do, AND what kind of tires you're talking (*****--dual sport--street?) regarding tire pressure. If you're off road, you probably don't want really high tire pressure for several reasons; better grip, better "float" and absorption of shocks to the tires, etc. If you're ON road, a bit higher pressure is good to keep the tires cooler, better handling (less wallowing), tire wear, and general safety in the corners (tires popping the bead, etc.)
