Busted shifter shaft
Old 07-28-2020, 03:18 PM
snappster's Avatar
I would think the plastically deformed Al case was work hardened, and like a bent aluminum clutch/brake lever, will break if bent straight if it is not annealed first. Much easier to heat a lever and straighten than a hole in the case. It seems to me that the annealing temperature of brake levers is very close to the melting point as I have melted a couple while attempting to straighten them. Now that I look up annealing Al I see that there is a time at temperature element of .5 to 3 hours. Not knowing the actual temperature of the lever, I have probably gone well beyond the annealing temp thinking I needed a higher temperature when I needed more time. 600F to anneal vs. 1200F to melt, give or take. Having learned something, I can call this a good day, thx.
https://llfurnace.com/blog/types-of-...at-treatments/
Mark Paul
06-26-2017 12:50 PM
Gwolf
06-01-2017 02:40 AM
MeanGreenMachine
05-10-2016 04:14 PM
Carly1
KX250 & KX250F
10-12-2006 11:57 PM
Quick Reply: Busted shifter shaft
