Burned Filter and Cage
Old 10-04-2016 | 03:41 PM
Spitfire44's Avatar
Default Burned Filter and Cage
Last week had a couple of spills. Carb got flooded and the bike was hard to start. Actually had to push start it. It wouldn't start with the magic button.
Must have back fired through the intake and started a small fire. Left a hole in the filter and a melted the air filter cage. Second time this has happened.
I try starting the bike with the throttle closed. Throttle open. Seems to just want some cranking to clear the gas. I never hear the carb backfire. But it must to start the fire.
Not a cheap fix. Bike has a Mikuni TM36 carb. Stock air box, except cover will additional holes.
Any suggestions on how to prevent? Does anyone make a metal cage that won't melt?
Old 10-04-2016 | 06:49 PM
That's kind of scary!
Is the backfire screen still intact?
Old 10-04-2016 | 10:39 PM
durielk's Avatar
I would put a new plug in it, gap it! Something is making it backfire, which mine has never done.
If it is flooded. Don't pump the throttle, with your carb, start it with full throttle, if you give the starter a break, don't close the throttle, keep it wide open. Eventialy it will clear and start... usually.
Old 10-05-2016 | 12:59 AM
2veedubs's Avatar
Try the K&N filter. Probably cheaper than a new filter and Oem cage. Might be less likely to burn?
Old 10-05-2016 | 02:34 PM
Spitfire44's Avatar
Thanks for the replies. The backfire screen is still intact. I try not to twist the throttle more than I need to. Usually start by leaving the throttle closed. When that doesn't work, then open it all the way. If the bike was laying on it's side for a while, then no cranking will start it. Have to ride it down the hill and jump start it.
I looked for a K&N, but the website I searched didn't have one for the KLX. Was thinking it would be a better option than the foam filter. I'll keep searching.
Old 10-05-2016 | 03:31 PM
zomby woof's Avatar
Replacing the filter with something else is not the answer. set the carb up properly or it will just happen again.
Old 10-06-2016 | 12:00 AM
I knew there was some reason for that...
Of course I cut it out of mine...
Old 10-06-2016 | 03:44 AM
You notice it didn't keep the OP's filter/cage from damage. I think these things were designed for lawyers as much as real world fire insurance. After decades of having 4-stroke dirt bikes that I've removed the airbox screen from, I've never had one incident of burning or damaging a filter, cage, or airbox.
I've had my bikes upside down in a crash with fuel running out and still no issue. Hard starting from a crash?...yes...but no airbox fire and such.
Old 10-06-2016 | 02:26 PM
Spitfire44's Avatar
Agred. What's the solution?
Old 10-07-2016 | 12:24 AM
I'm guessing zw is suggesting checking your carb setup as far as jetting and fuel level...or maybe something else.
I'll add that I have a similar setup as yours with the 36mm pumper and airbox lid modified for more air...backfire screen removed. Like I said, I've dumped mine upside down on some occasions with fuel running out of the carb and tank overflow. Took a good bit of cranking with the throttle slide wide open to refire, but it never has resulted in any filter or airbox flame.
This used to be more of an issue when we had points and/or adjustable timing, but our bikes have no such issue. I'm wondering about your valve clearance possibly if everything in your carb jetting and fuel level are good.
You mention this has happened twice even with the screen in place. Something isn't right.
markmeinteil
07-18-2008 07:31 AM
cosmickites
05-06-2008 10:39 PM
hoedogg
03-15-2008 01:53 AM
deej
11-27-2007 08:28 PM
bryantjt
09-22-2006 12:10 PM
Quick Reply: Burned Filter and Cage
