Broken Tail Light Weld - How to Fix?
Old 08-02-2009, 01:51 PM
advtouring's Avatar
Default Broken Tail Light Weld - How to Fix?
Hi, The weld on the tail light broke under the weight of the over sized light. Ok maybe that's because I had to bend it back into place a couple times. Has anyone replaced the tail lights on their 06-07 with an after market product that dosen't require the metal tab to be there and doesn't require replacing the rear fender? Ideas and suggestions are welcomed (yes, I could find someone to weld it back, but what fun would that be?).
Old 08-02-2009, 10:14 PM
LearjetMinako's Avatar
I has been done. Some folks on here replaced their oversized blinkers with some low-profile ones that attach to the fender.
One of the welds broke on mine, I just went and got it re-welded on both sides of the bracket. Now its even tougher than before.
Old 08-02-2009, 10:38 PM
skubidoobie's Avatar
JB Weld!
Old 08-03-2009, 01:08 AM
IQOUTLAW's Avatar
Ive gt a stock rear fender w tailight assembly in it that is for sale...I am putting it along with a lot o other parts(w pictures) in the classified ads as we speak!
Hit me up if you are interested!!! I swapped out the stock rear fender for a kx fender and an electrosport taillight n blinkers all around. Lots of customization but looks killer!
Good luck!
MAXX
Old 08-03-2009, 01:19 AM
JasonFMX's Avatar
Originally Posted by advtouring
Hi, The weld on the tail light broke under the weight of the over sized light. .
You mean the rear turn signal.
When I read that I was like "huh?...tail light bracket??, you mean the fender broke?"
Old 08-03-2009, 01:22 AM
WestOzKLX's Avatar
screw some of these to the rear guard. Job done.
Old 08-03-2009, 01:54 AM
neilaction's Avatar
I went for these.
Front and rear.
Quite small, flexible rubber mount and spare lenses are cheap as.
Not the best looking though. but tough.
Old 08-03-2009, 02:49 AM
IQOUTLAW's Avatar
Im also selling a set of stock rear signals in excellent shape! Pics in classified section. If you are looking for aftermarket...ELECTROSPORT flexable LED low profile are killer check em out!!
Attached Thumbnails Broken Tail Light Weld - How to Fix?-klx-back-left.jpg   Broken Tail Light Weld - How to Fix?-klx-right-rear.jpg
Old 08-03-2009, 01:43 PM
advtouring's Avatar
Where can I find these?
Old 08-03-2009, 01:44 PM
advtouring's Avatar
[QUOTE=neilaction;387911]I went for these.
Front and rear.
QUOTE]
Quick Reply: Broken Tail Light Weld - How to Fix?
