broken camshaft cap bolt
When finishing my valve adjustment I over torqued the bolts of the Cylinder Head Cover that threaded into a rise on the camshaft cap.
There is no parts number for the camshaft cap because I think they are made as a set.
Does anyone have any experience with welding the threading back on the camshaft cap or I am into a large cost.
If the treads are stripped in the cap then a helicoil would be the way to go. As a welder/machinist/aircraft mechanic/blah blah blah, I'd be a little hesitant to just patch a critical part like this up. Idk how much stress these caps are subjected to but I'd feel better with a brand new part in there. Its just unfortunate if you have to buy them as a set
the treads in the camshaft cap
I split, into 3 pieces the threading on the camshaft cap from the bolt that is in the cylinder head cover. Sorry I wasn't clear about the issue. The bolt is fine, just the raised casing of the threading split. The camshaft cap while a separted part isn't sold as such. I have to purchase the entire cylinder head for over $500.00 ? Or can it be welded ?
Looking at a pic, I think I see what you're referring to. It's not just stripped...it's actually cracked in pieces where the valve cover bolt goes...correct? That's going to be tough to fix. I'd have to see a pic of how much it's broken and how far down.
We are talking about a bolt for the valve cover? Just use silicone on both sides of the gasket, leave the bolt out & silicone the bolt hole. If it leaks a little oil, add a little oil. If it leaks a lot of oil, then worry about a fix. I don't see any pictures, which bolt, which threads, etc.
