broke my brake light switch wire
Old 05-24-2014 | 03:49 PM
kennysupermoto's Avatar
Default broke my brake light switch wire
on the progress of replacing my handle bar, the brake light switch wire broke
where can i get them, and what's the correct search term.
Thanks!
Old 05-24-2014 | 04:09 PM
Looks like you may be lucky. If the switch itself isn't damaged, you can just trim your wires back a hair and put matching female connectors to attach to the switch terminals.
Old 05-24-2014 | 04:17 PM
Yah, just did that but the mess! btw if i have to get a get a new one, do i have to buy a new start switch full set up?
Old 05-24-2014 | 08:28 PM
Shouldn't be a mess. Two female spade connectors of like size and some nice heat shrink, and you should be good cosmetically. If you're going to use some electrical tape, use that higher quality 3M stuff...don't remember the exact part number.
I think the part you'd probably need if I'm looking at that pic correctly would be the handlebar wiring harness...complete if I had to guess. That would be ridiculously expensive for such an easy fix IMO.
Old 05-25-2014 | 05:26 PM
drm's Avatar
drm
http://www.amazon.com/gp/aw/d/B008FZ...&robot_redir=1
how about "right angle female spade terminal"
Old 05-25-2014 | 05:37 PM
RaceGass's Avatar
Hell if your stuck pry the tabs up and reuse them. Solder sparingly... Mcgyver man!
Old 05-25-2014 | 07:01 PM
THANKS A LOT! made my day
dan888
03-09-2012 02:57 AM
CousinLarry
12-22-2010 02:33 AM
kronus
06-27-2008 01:27 AM
shinobi636
01-05-2007 05:25 AM
Quick Reply: broke my brake light switch wire
