Breaks Squeak
Breaks Squeak
Wanted to know how to get my brakes to stop squeaking? I still have a lot of pad left of the brakes. Could they be glazed over and need to be sanded down? Any quick and easy ideas to fix the problem?
Larry, I want to be able to stop too. Do you think that I can just put the oil on the discs and roll it while hitting the brakes? Don't want to un-bolt the brakes, if I don't have too.
Tonight,
-get out beers
-get out stokies if you like them
-park bike on stand
-sip beer/toke stogie
-pull off brake caliper
-pull out brake pads
-look at everything for a bit
-sand off brake pads
-clean rotor with alcohol (not beer, but the rubbing type) or other cleaner
-put brake pads in calper
-install caliper
-observe the good work you've done
-pat yourself on the back
-then take another sip beer/toke stogie
-THEN suddenly remember to pump up the brake!
-smile with relief and sip beer/toke stogie
-repeat on other brake
I find itemizing my process to work well.
-get out beers
-park bike on stand
-install caliper
Just curious. How many miles on the bike? Did you just replace the pads? If so, what kind did you use? What do your rotors look like? What have you tried so far to get rid of the squeal?
