Break in service.....
Old 07-29-2008 | 01:49 AM
AllieCat's Avatar
Default Break in service.....
Just wondering if I should take the bike to the dealer and let them do the 500 mile break in service or should I do it myself? Any concerns with the warranty if I do it? And is there anything I can screw up?
Old 07-29-2008 | 03:33 AM
lcpl0331's Avatar
do the work yourself. they won't be checking your valves anyway so what's the big deal? change oil/filter and check all your bolts for tightness. make any cable/chain adjustments you think are needed and your done. the oil and filter are the big one. don't be overly concerned about all the torque settings for each bolt. just put a wrench on them all to make sure they're not loose.
PS. make sure you pull off the seat to check you air filter. if i recall correctly they come from the factory dry as a bone and sometimes the dealer forgets to oil it up.
Old 07-29-2008 | 03:47 AM
KDXmike's Avatar
I skipped it. Changed the oil myself and had the valves checked at 2600 miles. They were in spec.
Mike
Old 07-29-2008 | 02:53 PM
cliffsta's Avatar
Ditto. Changed my oil and filter around 450 miles, didn't bother checking the valves. We cleaned and oiled the air filter. The filter was oiled but it was some really poor filter oil so we cleaned it all out and reapplied some of the good stuff.
Checked tightness on some bolts, looked at fluids, that's about all we did. Gonna change the oil again at 1500 miles.
Old 07-29-2008 | 03:10 PM
chris72a's Avatar
Default RE:
I asked my dealer what the 1000kms service involves, they said it was just checking every nut and bolt.. I save $225.00 Doing it myself, wasn't brain science.
Cheers
Chris.
dopeysw20
04-22-2008 09:09 PM
Bluebeast
06-15-2007 08:55 PM
incabiker
03-05-2006 06:14 AM
ryninger
06-26-2005 06:58 AM
greenrider
06-07-2005 07:17 AM
