bleeding the front brake
Old 09-27-2008 | 08:18 PM
nosneb69's Avatar
Default bleeding the front brake
HI to all, I have just got some braided brake lines from bill blue. I got the back on and it works great but when I got the front on it all turned sour!! I can not seem to get the brake line primed and the air out.....?
has any one got any tips?
cheers - safe riding
Old 09-27-2008 | 08:24 PM
kgwld1's Avatar
Get a hand vac harbor freight has them,I use a snap on power bleeder it takes me less time then it did for me to type this.
The harbor freight hand vac is real cheap in price also any auto motive store has hand vac that have many other uses good luck.
Old 09-27-2008 | 08:28 PM
nosneb69's Avatar
alright fella, I wish it was that easy!!!!! I live on a small island in Honduras and there are no automotovie store!!!!!! I will just have to get the girl friend to suck on it!
cheers
Old 09-27-2008 | 08:34 PM
kgwld1's Avatar
Well sounds like your out of luck, hand pump the brake while cracking the bleeder open and closed while that girl does one or the other.
Old 09-27-2008 | 08:37 PM
AgoosSS's Avatar
I've had good luck using a syringe, pushing the fluid up from the bottom.
Old 09-27-2008 | 08:39 PM
nosneb69's Avatar
Now that is what I was thinking.......any how I think I will go and try both ends.
I will let you nkow how I got on in a few mintues
cheers again!
Old 09-28-2008 | 04:42 AM
WestOzKLX's Avatar
Speed bleeders help. Not sure if you'll get them in Honduras.
Old 09-28-2008 | 02:22 PM
a16tony's Avatar
I hated bleeding that puppy.
Do your normal bleed procedure to get the air out of the caliper. Now strap the brake lever in a half brake position(be sure the reservoir is full), and the lean/lay the bike on the left side as to have the master cylinder as the highest point in the system, or take it off the bars to raise it. Wait over night and in the morning you should be able to work the lever a few times and get the air bubble to flow into the reservoir.
Old 09-29-2008 | 11:11 AM
ddt1972's Avatar
+1 for speed bleeders. Just got a set on my bike. Very nice indeed. Can be ordered online, even on ebay.
Juliet
06-29-2010 02:23 AM
Daves_636
09-12-2007 04:52 AM
digitaloverkill
08-03-2007 02:45 PM
dacevoit
ZRX1200
06-18-2007 09:58 PM
jkarner
09-09-2005 06:03 AM
Quick Reply: bleeding the front brake
