Blacksmith's Anvil
RE: Blacksmith's Anvil
Then use a bread knife to cut a series of parallel cuts to the correct depth. Cut these about 1 inch or so apart. This is so you can cut each one out seperately and better control the depth:
This is how I did the sides - I left the top full width because I wanted the resultant seat to be a little bit wider than the stock seat which will happen when the gel pad folds over the edge. If you want to maintain the stock profile, trim to taste:
