Black rims on red 09
No problem. Since you've never laced a wheel before, maybe this will help you out...
https://www.kawasakiforums.com/forum...oration-31657/
Before taking your stock rims apart, measure the offset. Put a straight edge against the rotor, and measure the distance between the straight edge and the edge of the rim. Unlike bicycles, motorcycle rims are almost never centered on the hub. Once you get your new rims installed and trued, take this measurement again, then turn the left or right spokes to make it match. The offset with the new rim should end up being pretty close, but it never hurts to double-check.
If you're just changing the rims and keeping the stock spokes, here's another tip. Before taking anything apart, use some masking tape and tape the spokes together wherever they cross. Then take the nipples off and wiggle off the old rim, but leave the spokes in the hub. When you put the new rim on, just line up the holes in the rim with the spokes. This way you won't have to figure out which spokes go where.
Damn ive tried everything to get this bolt out, tried vice grips, dremaling a grove for flathead screwdriver and got a both extractor too but none of my bits will drill a whole in this bolt. Anyone have experience removing one of these bolts.
A picture of the offending bolt would help us help you. Can you get a pair of vise-grips on it? An excellent penetrating oil like Kano-Kroil will help. Some also swear by PB Blaster oil. Heat will usually help but I wouldn't try any more than a heat gun on the fork there.
Let's see what you're working with.
Don't start swinging with a hammer if you get frustrated.
Patience and persistence will usually win out.
Dan
Dan
Are these actual pictures or are they photo shoped. The left hand guard is in the same postion in all 3 places on the siding of the building. Also the valve stem is in exactly the same position on the front wheel in all 3 pictures. If they are all real pictures how do you get the bike back in the exact same position for all of the pictures. I love the look of the gold wheels.
