bill's front brake line
RE: bill's front brake line
ORIGINAL: Shadetree
I guess one has to decide for himself how much it helps, but I like the stability I got from mine.
ORIGINAL: Divodave
How much benifit has been reported?
ORIGINAL: Nobrakes
I'd describe it as subtle, until you need it, and then there's now doubt that it is working. The main effect that I've seen is that if you are flying down the trail and hit an angled root or rock, instead of deflecting the wheel sideways, it will deflect mostly up and over. I've noticed it helping at slow speed too while going over rock garden type terrain it's a lot easier to stay on track, you are not fighting the bars so much.
ORIGINAL: Shadetree
ORIGINAL: Divodave
I figured I would spent the several hundred bucks elsewhere first. Eventually, I may end up finding out for myself, but currently, its not high on the priority list. But if the next bike comes with one installed, I probably won't immediately remove it either.
Wow. Sorry to blast through the original thread here, but one more time...
Dan, Bill's stabilizer isn't all that expensive. Probably under two bills if he finds one worth the money like the one he found for me. That's under half what a Scott would cost...even if it would fit with the Clarke tank. As for steering stiffness in the slow stuff, yes, you can feel it some, but the benifit seems to outweigh any negative effect. At speed, especially highway speeds, it's like giving the bike a mood modifyer, making it much more managable and easy to relax on while riding.
Now, back to your regular broadcast...
Bill Dragoo
Norman, Oklahoma
Bill Dragoo
Norman, Oklahoma
I think the 'old timers' that Dan is speaking of are assuming that any stabilizer you get will dampen thoughout the steering range in both directions. Not so with the off-road W.E.R. It only dampens on deflection FROMcenter, not during return. Also, it only dampensthrough somany degrees of deflection (something like 20) and gradually tapers off the dampening as the endofits range is reached... I think technology has advancedbeyond those old timers' frame of reference.
ORIGINAL: Shadetree
Bill Dragoo
Norman, Oklahoma
Bill Dragoo
Norman, Oklahoma
ORIGINAL: dmar
any reported problems of the brake line hitting the tire. seems like over bumpy areas the line could bounce into the tire.
