bill blue 351 install instructions
yeah, my local kawi dealer didnt have the pilotjet... 4 dealerships called and none had it.. go figure..
soooo,,
the P.o. used a heli coil on the camshaft cap.. when to put it back on and the bolt jsut kep spinning in palce... backed it out and a helicoil came out with it... anyone have any good ideas for a good fix? Another heli coil? tap it to a size larger?
Wow! I'd call and thank the PO for sticking you with that mess.
Sounds like he didnt install the Helicoil correctly. I'm no expert, but I would try to install another one of the same size. If it won't stay in place see about going to the next bigger size.
Good thing you caught that before it went catastrophic.
Good luck\
Dan
Good luck\
Dan
