Bill Blue 350 kit with a stock bike
Old 02-10-2009, 02:15 AM
Bake's Avatar
This past weekend I pulled the front end off and cleaned up the head bearings, and re-greased them real good. That took care of a little bit of trouble I was having in the steering. As it came from Thailand, they were not over greased, that's for certain.
I installed my heated grips, that is a sweet deal to have a couple of differnt heat settings. I can ride in 50F weather with unlined deerskin gloves. The handguards breaking a little bit of wind plus the grips is all it needs.
Had some good luck finding a new tire that matches the Kenda 50/50 rear. I'm running the rear K270 4.60-18
It's matching Kenda 50/50 front is junk.
But this new tire is great, street or dirt.
K776F 90/90-21.
  #52
Old 02-21-2009, 02:49 AM
Xplosivo1's Avatar
Bake,
Do you have the Dyno information available yet?
  #53
Old 02-21-2009, 05:39 AM
Bake's Avatar
I haven't scheduled a dyno run yet, no. I've got a lot going on just now with work and stuff.
  #54
Old 02-21-2009, 05:35 PM
boxermachine's Avatar
What's the compression ratio on the 351?
  #55
Old 02-23-2009, 12:23 AM
b_joannblue's Avatar
The compression ratio on the 351 is 12.5:1 We are still using regular pump gas no ping or spark knock.
Bill
  #56
Old 03-02-2009, 06:44 AM
Xplosivo1's Avatar
Two quick questions:
What counter sprocket are you using? And, what kind of gas mileage are you getting with the kit?
  #57
Old 03-02-2009, 12:59 PM
The stock 14T countershaft sprocket stock rear sprocket.
Haven't checked gas milage yet.
  #58
Old 03-03-2009, 12:55 AM
Xplosivo1's Avatar
Thanks, please post it when you have a good figure. I am ready to make a purchase, but im not sure which kit would be the best for my situation. I am keen to the 350 kit, but want to make sure I wont NEED a larger tank, or to carry fuel bottles.
  #59
Old 03-03-2009, 03:38 AM
Bake's Avatar
It's going to be warm in a couple of days, I'll go out and roll up some miles, and get some numbers for you on the gas mileage with stock pipe and carb.
  #60
Old 03-03-2009, 05:01 AM
Xplosivo1's Avatar
Thanks Bake, I'll be anxiously waiting
Quick Reply: Bill Blue 350 kit with a stock bike
