Bike won't rev past 5k
i took it out of the garage today, wharmed it up, took it for a ride around the yard, and it tried to kill me. got to a spot where i needed to accelerate, and it bogged down like it was out of gas, and now it won't rev past 5k. plenty of gas, changed the petcock to reserve just because, and it still wont rev. pulled the plug and it shows its running rich. its bone stock with the exception of the dealer drilling out my pilot jet to 38. any quick ideas before i take it back and make 'em fix it under warranty? im kinda thinking that when they drilled the pilot out caused it to run to rich, and clogged the cat.
intake is fine, i took the lid off and tried it, but it still bogged. as for the exhaust, im thinking clogged cat...who's bright idea was it to put a damn cat on a dirtbike anyways...thanks cailfornia
Before you start jumping the gun with major problems. Start with the smaller stuff first. For starters, it could be the needle is stuck partly open or the fuel bowl float is out of spec. Try draining the fuel bowl first and try some carb cleaner additive.
