Bike sat a couple years. Crank won't turn by wrench...
I started a valve adjustment a couple years ago and never got around to finishing it. Last weekend I put in some new shims and reinstalled the cams and tensioner. I went to turn the crank by wrench, but it will only go about 90° either way. Anyone know what might be keeping it from rotating fully? I don't wanna try starting the bike up with it getting stuck like that.
Bike is an 09 KLX250SF by the way.
Last edited by Dragaleen; 07-17-2021 at 11:31 PM. Reason: Letting them know the bike model.
Hmm. I turned it to TDC, put the cam gear lines parallel to the head, and have the In and Ex markings 32 pins apart. Have any further details on that process I might be missing? Thank you
Be sure to reset the plunger in the cam chain tensioner.
Ride on
Brewster
Looking at the head I noticed I only have one dowel pin (at bolt 6 on the retainer). Am I supposed to have another? It looks like there's space for another dowel pin above the threads of bolt number 1?
If I'm missing one I wonder if it's fallen down into the case and is jamming something.
