Big bore the KLX or buy somethng new?
When I looked into the big bore options for the 2007 model engines like I have, I was told it didn't have the same compression release as the KLX-300. I this something added to newer KLX-250's that wasn't on the older ones like mine?
I have a KTM 450XC-W for big power off road. I have considered the plated 350EXC-F option but, I dont' really want to drop $10K on something that comes close to replicating what I already have. For the $10K option, I would go with the KTM 690R with the 700 cc LC-4 motor.
The Kawasaki suspension is it's weak point. However, it is a true low maintanance dual sport and it works well enough. What I want is more motor to run 60MPH without reving so hard. I want an 80% street commuter with a 20% easy off road option. A 650 thumper is an option but, I don't want something that heavy or soft off road.
If you're used to riding the KTM, then yes, the KLX and the WRR will need revalving to achieve performance approaching the WP stuff. I did the Gold Valve deal front and rear on mine, and it totally changed the off road character of the bike. Still, with your 80/20 description with the 20% being "easy off road", one of the 650 DS bikes should easily fill that. On my modded KLX I can ride most anything off road that I used to do on my enduro race bikes...just at a slightly slower overall pace. The funny thing is that this KLX will climb gnarly, loose stuff as good or better than some of my race bikes.
Sid,
I did the 331 and went to a 15t front sprocket. It cruises easily on county highways(55mph). And has power to spare for passing, just roll on in 6th and 80mph pops up pretty quickly. The change to a BB is quite dramatic, if you can find a fellow klxer near you to help or a friend who knows what they are doing I would go for it. Great bang for the buck!
Sid, on the 60mph pavement cruising, I don't like to rev the guts out of my KLX. Mine easily cruises at a true 60mph all day with 14/47 gearing...that's a 5-tooth bigger rear sprocket. This is a highly understressed engine and 60mph doesn't challenge it a bit unless you've geared way, way down.
Regarding the 650 dual sports, I just don't want that much weight. Arm pump on the KLX is bad enough. On challenging trails, I can pick my way through the boulder fields. And sandy washes, the KLX is bad enough, I can't imagine another 80lbs and struggling through successfully.
I also want to keep a lower maintanance long life street motor for the bulk of my asphalt cruising and leasurely rides. A 650 Dual Sport is tempting at times, though a plated KTM is tempting too. A 351cc KLX-250 seems like a possible solution at much lower cost and easier relaxed maintanence routines.
I've taken the KLX on one highway ride that was ~110 miles each way when some idiot totaled my car. The buzz really bothered my hands and I didn't have enough power to really run with traffic (70 MPH on I-10). Being passed by big rigs pulling enclosed trailers was a real experience ... So were the rain grooves in the I-10/I-19 exchange.
I've got over 10K miles on the KLX with a lot of easier trail rides but, I'm still learning on the KTM. I consider myself an experienced amatuer or begining intermediate rider.
I also want to keep a lower maintanance long life street motor for the bulk of my asphalt cruising and leasurely rides. A 650 Dual Sport is tempting at times though.
For what it's worth, I like my 14/47 too, but am still running as a 250.
The 351 is next, love the gearing, just want more HP not a bigger/heavier bike!
Then I'll save up for suspension mods, but with rim locks and low air pressure the KLX is light and stable in the woods, while climbing like a goat through rock fields!
Now, like TNC noted...about those boulder fields on the easy trails?
Maybe you mean slow, not easy? I ride gnarly stuff, just pretty damn slow, but getting faster!
And yes, I ride slow in those areas because my off road confidense is low. I also figured out that I really needed to carry more speed through some areas because going slow was causing me problems too.
I'm not a hard core experienced single track, enduro, or motorcross racer but, I do ocasionally go to rough areas. I just don't live in them and spend most of my time doing more mundane things as I earn a living.
So, no I'm not a gnarly single track junkie. I'm sowhere past beginner but, I'm not a gnarly trail guru either. My off road experiences are a small part of my total motorcycle time though, I do travel to gnarly areas to try and build my skills.
Since I was doing a lot more freeway riding than I initially thought I ended up with a different bike. A Ninja 500. Night and day for that purpose. It was cheap and it is really a fun bike. That way I got to keep the KLX. The combination was less than a really nice DS as mentioned so I am pretty happy with the trade offs.
Having two bike is nice since I am doing all the the maintenance. If a bike is down for a couple of days that is ok since I will just ride the other. Having no car makes that kind of nice
Sounds to me that a big bore kit for your 250s will be your best option. Not very expensive or complicated, there are many threads on this forum that will walk you through the process. Also alot of good help on this forum if you run into problems.
If you decide to make the step up to a 650 and dont want to gain alot more weight the 3 options I'm aware of are the ktm 690 (expensive but a good bike), honda's 650 (air cooled which can be a big problem in deserts), and a kawasaki klx650 (old and harder to find).
