Best LED turn signals?
New (to me) '06 KLX250S and looking for some smaller-than-stock front & rear LED turn signals that will A) bolt on to the stock locations, and B) use the stock bullet connectors. Is there such a thing?
Thanks!
Thanks!
All I know is that you need to fit a resistor to the LED signals if they don't come with one fitted. Most of the new ones I've seen have them installed now. Try Oxford Products, they have a large range of products.
Check these out!
![](http://www.oxprod.com/photo.php?id=1047)
http://www.oxprod.com/index.php?pg=3...id=26&pid=0&p=
Check these out!
Actually I suppose they don't have to be LED, just something small, still visible, and fits stock mounts/connectors. I see Oxford has a full line of "mini" and "micro" signals.
In europe most street legal bikes and ATVs (yes, streetlegal ATVs/Quads) with the
signals below, my first mx bike (motohispania furia) came with them, bright, not to
big and very flexible, i had at least 8-10 crashes they never broke.
![](http://ecx.images-amazon.com/images/I/41J0ZX0nx8L._SL500_AA280_.jpg)
Amazon sells them cheap:
http://www.amazon.com/TURN-SIGNAL-KI...335287&sr=8-15
![Name: IMG_6411.jpg
Size: 62.0 KB](https://www.kawasakiforums.com/forum/attachments/klx-250s-71/22200d1501293691-best-led-turn-signals-img_6411.jpg)
Here ya go, my fav for front blinkers anyway. Pretty stealth, they blend right in and can't see em until I turn them on really. Flexable too. They come with a resistor to slow down the flash to compensate for the led's.
i would recommend the bikemaster mini-stalks- the ones that arnt LED. i have the incandesent (sp?) ones and they are just as bright as my buddy's w LEDs- minus the stupidly fast blinking...
From what I'm gathering if I go with LEDs I'll need a different flasher relay, correct?
I don't think that's correct. I think you just have to get the LED blinkers with a resistor in the line. Most of the new models already have them and blink at the normal rate.
It's an either/or type of thing. If you install a solid stated flasher, you don't need to worry about using a resistior for each LED signal you install. The solid state flasher also works with both the normal and LED lights.
