Bent my handlebars. What should I Buy?
Old 08-25-2020, 04:37 PM
Sid Post's Avatar
Originally Posted by apexal
I'm jumping into this late but not quite getting the info that I need. I just bought a new 2020 KLX250 and want to replace the bars before I add barkbusters. Can anybody tell me what aftermarkey bars are closest in size and shape to my stock bars? I do not want any problems with the cables. Or could you recommend a bar to work with the stock cables? Thanks!
I use Honda CR "High" bars from ProTaper. The stock height bars on my 2007 KLX-250S were too low for me standing on the pegs even though I'm only 5'6". The factory steel bars also are not very strong if you dump your motorcycle on the trail so, I'd opt for some strong Aluminum bars if it were myself at this point in time. The CR 'high' bars work really well for sitting with a little more sweep back even though they are slightly wider. This makes leverage on a hard rut better too. In my case, no issues with cables stretching tight on a tight parking lot maneuver either.
  #32
Old 08-25-2020, 04:49 PM
apexal's Avatar
But will they work with the stock cables? I'd like a taller bar myself but don't want to have to replace cables. Thanks!
  #33
Old 08-25-2020, 05:03 PM
Sid Post's Avatar
On my 2007 KLX-250S, the only thing I needed to change were the grips since I also did Acerbis bark busters. The stock cables on mine were plenty long enough. I can't speak for the more modern KLX's but, if you have a little slack with the steering locked going both directions, I suspect you wouldn't have any issues with the stock cables either.
The only thing I can think of would be adjusting them really low and putting more stretch into the cables. With a normal height, I would think you would do fine with the stock length cables though, a simple cable swap is easy and cheap if needed.
  #34
Old 08-26-2020, 12:16 AM
apexal's Avatar
I don't want to replace cables and/or brake hose if I can get bars that avoid that. The ProTaper CR high bars sound like a good recommendation and I've seen other members say the same. So that's probably going to go with. Thanks for the info!
Feral Donkey
05-03-2010 03:44 AM
punkenduro09
07-18-2009 10:43 AM
MADDOG2007
02-18-2008 06:09 PM
tremor38
09-07-2007 12:17 AM
justin
05-31-2006 06:49 AM
Quick Reply: Bent my handlebars. What should I Buy?
