Battery? Or more...
Old 06-22-2015 | 03:17 AM
MaximusPrime's Avatar
Check the main fuse again.
And you're sure your friends battery was good and the right size to start the bike?
Sounds like a bad battery still. Once it's dead, it's dead.
Get a battery, charge it, and install it, make sure the big main fuse is good, and then fire it up.
Old 06-22-2015 | 10:13 AM
Michaelb2's Avatar
he took the battery out of his working 2012 KLX250s.
Where is the main fuse?
Old 06-22-2015 | 11:00 AM
Under the seat. It's bigger than the rest and by itself (it's a normal size bladed fuse, the others are small ones).
Old 06-22-2015 | 11:35 AM
113moro's Avatar
Check your grounds
I am going through a similar thing
I believe it is my battery
Old 06-22-2015 | 12:09 PM
Michaelb2's Avatar
I'll look tonight for the main fuse.
113moro - keep us updated.
Old 06-22-2015 | 12:25 PM
surferdude's Avatar
How about the alternator or voltage regulator?
Old 06-22-2015 | 12:50 PM
Michaelb2's Avatar
Good question, surferdude. I'm not familiar with how to diagnose or troubleshoot them. Any ideas?
Old 06-22-2015 | 02:30 PM
anciano's Avatar
Ignition switch?
Old 06-22-2015 | 03:36 PM
durielk's Avatar
If his headlight is not working, the regulator/alternator will be way down on the list at this point.
With the nic "surferdude", probably should just think about it a bit?
Old 06-22-2015 | 03:53 PM
ol'klx-er's Avatar
michaelb2, do you have the owners' manual? It shows the fuse locations. There was a post recently that mentioned the owners manual is a free download from Kawi.
Quick Reply: Battery? Or more...
